2000 Accord v6 hesitation when starting and going into D
Old Dec 10, 2017 | 07:51 PM
MH2000AccordV6's Avatar
Default 2000 Accord v6 hesitation when starting and going into D
Hi everyone,
I am new to the forum and need help. The issue i am having seems very common to these models etc.
Basically the car runs fine for few days, then suddenly one day when u start the car all cylinders will start to misfire and check engine light will lit-up.
During this time if u keep the gas enough the engine wont die but it will die at idle.
So what i do is i rev the engine enough and immediately put it in D and drive. If i wait any longer the engine dies. As soon as you drive and engine gets into 2 or 3 gear the car runs smooth again.
This might not repeat for days or can surface again on the next start. Every time u pull codes they are just cylinder misfire only, no others code show up.
My car is at 150K miles and i put in platinum plugs at 120K miles.
Does anyone know precisely what this mess is, i am totally frustrated and it is becoming a hazard driving the car.
HELP>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Old Dec 13, 2017 | 12:08 PM
Amie Cruppenink's Avatar
Default Re: 2000 Accord v6 hesitation when starting and going into D
hi. I have a question for you...
Old Dec 13, 2017 | 12:09 PM
are you here?
Old Dec 13, 2017 | 12:14 PM
holmesnmanny's Avatar
scan it for codes
Old Dec 13, 2017 | 12:47 PM
Codes show as random misfire on all cylinders.
Old Dec 14, 2017 | 09:05 AM
check mechanical timing, if good i would replace crank sensor assembly and clean real good the areas of the crank that the sensors read off of
Old Dec 15, 2017 | 09:19 AM
somick's Avatar
What is the condition of the distributor cap?
Good luck,
Sam
Old Dec 17, 2017 | 06:14 AM
poorman212's Avatar
Does this seem to happen when trying to restart the car after it has been driven enough to be at normal op temp....like you have been driving, pull into a store, go inside for a few minutes then come to restart the ar and this is when the issue happens........or will it do this from a complete cold start?
Old Dec 17, 2017 | 07:11 AM
Poorman212 yes I think mostly this is when it happens mostly or in fact i cannot remember anytime it did that from a cold start???
Old Dec 19, 2017 | 04:31 PM
poorman212's Avatar
Many of the 6th gen (98-02) v6's suffer from "heat soak" when you go through the drive...short stop time...re-start. It really shows up in the cold when "winter blend" gas is being sold.
"IF" this is your issue, you need to remember more of when it does happen, the "fixes" are from one end of the spectrum to the other. How you decide to try to resolve/reduce it from happening are going to depend on you.
Old Dec 19, 2017 | 10:12 PM
try this to test, buy some ice packs, drive and warm it up, park at your house, try to duplicate the non start issue
when its not starting throw the ice packs on the fuel rail, wait a few minutes or so and try to start it
MTapester
Apr 1, 2011 11:41 AM
gen2tegboi
Dec 31, 2009 08:17 AM
CFP_IVAN
Nov 24, 2009 06:17 PM
g0rd0n
Apr 17, 2006 08:10 PM
addision
Mar 13, 2006 08:42 AM
