Suspension & Brakes Theory, alignment, spring rates....
BBK theoretical problems
Old Dec 10, 2017 | 09:25 AM
RobRac's Avatar
Icon5 BBK theoretical problems
So I've heard that many people experienced "spongy" pedal feel after installing Advics + 350Z's rotors. Is there anything I could do to prevent it (I'll be upgrading my 9gen accord coupe'c brakes in spring)? A different master cylinder? Any other ideas?
Old Dec 10, 2017 | 05:35 PM
Accordian47's Avatar
10 Year Member
Default Re: BBK theoretical problems
Booster? Braided Stainless Lines? Aftermarket Proportioning Valve?
Old Dec 11, 2017 | 04:40 AM
Fitz Williams's Avatar
10 Year Member
When I went to larger rotors with NSX calipers the brakes felt softer than my wife's car. They also stop quicker with less pressure which may account for the difference in feel. They have been bled numerous times and the "feel" stays the same. I would not describe is as spongy, but soft. The same amount of braking with less pressure. And no fade.
Old Dec 11, 2017 | 10:44 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Its a ~13% increase in pedal movement.
The CR-V/RDX/RL brake master *might* work in that chassis. Not sure.
Using a pad with lots of bite and relatively low compressibility will help.
I found that Bendix Semi Metallics work really really well in those calipers. Too bad they're discontinued AF. Get them while you can!
Old Dec 12, 2017 | 12:34 PM
RobRac's Avatar
Thank you guys!
Old Dec 12, 2017 | 01:04 PM
B serious's Avatar
no problem.
Avoid changing the MC as much as you can. You'll either need to buy a reverse bleeder or take it to Honda for an ABS actuator bleed.
wkendmechanic
Sep 23, 2012 05:22 PM
LS stretch
Suspension & Brakes
Mar 9, 2012 01:35 PM
crice
Nov 30, 2008 07:56 PM
Exploziveaf1
Jun 10, 2007 03:46 PM
matto23
13
Mar 28, 2005 08:18 PM
