Power front door locks not working - any guidance please?
Old Dec 10, 2017 | 08:28 AM
lpozzo's Avatar
Default Power front door locks not working - any guidance please?
Hi All,
I have a 2000 Civic DX (sedan) with 117k miles and I have a power door lock issue that I am not able to resolve and I would truly value any guidance. I have checked both fuses (engine and interior), wires to/from door and tested multiple scenarios.
Here are the observations:
· I locked and unlocked doors with both the interior door switch and remote key unit (Honda OEM fab) and I got the same results
· Both (driver & passenger) front door locks do not lock or unlock
· Both rear doors locks work fine consistently from the switch and double clicking remote unit (unlock button)
· When using the key in the driver’s door to lock, all the locks will close except the passenger side
· When using the key in the driver’s door to unlock, only the driver’s side lock opens
· It seems that the door lock actuator does click when trying to lock/unlock doors
What should I test next? Could it be the control unit on the driver’s side kick panel area? How can I test the door lock actuators?
I would appreciate any guidance. Thanks so much! Louis
Old Dec 10, 2017 | 09:11 AM
civic402lx's Avatar
Default Re: Power front door locks not working - any guidance please?
Check the door to chassis connection harness for physical broken wires. It js common for those wires to get frayed and come off their pins due to age. Open door, peel back rubber booth, check wires.
Old Dec 10, 2017 | 04:36 PM
lpozzo's Avatar
Thanks for the guidance, I️ peeled back the wires and the wires are perfectly fine.
Old Dec 11, 2017 | 08:23 AM
NVturbo's Avatar
O.G. triple O.G.
since when did DX models have power options? The idiot who you got the car from halfassed the wiring.
Old Dec 11, 2017 | 12:58 PM
lpozzo's Avatar
My 2000 DX model has only power door locks from the factory but no power windows. It has all the hardware installed from Honda. I guess it might have been an option at the time of purchase.
Old Dec 11, 2017 | 02:17 PM
tony_2018's Avatar
Fish Twig
Its probably an LX. Do you hear it trying to lock/unlock?
Old Dec 11, 2017 | 03:47 PM
lpozzo's Avatar
I do hear the locks trying to lock and unlock. Does this mean that the lock actuator is weak to perform the action?
Old Dec 11, 2017 | 03:48 PM
tony_2018's Avatar
Fish Twig
something could be jammed up if anything its probably on its way out.
Old Dec 12, 2017 | 03:52 AM
lpozzo's Avatar
I took the driver side door panel off and all the hardware looks clear of any jams. It does sound like the lock actuator may be bad.
I noticed that VDO and Dorman make a replacement OEM part. Do you have a recommended brand for the lock actuator so that it is a direct fit? Thanks.
pwyley
Acura TSX
Apr 2, 2018 02:32 PM
Jimi Hondrix
14
Sep 3, 2015 04:09 PM
Tonyl507
Mar 9, 2007 06:23 AM
Intercooler
Nov 18, 2004 08:43 PM
