t-belt question
Old Nov 11, 2002 | 07:42 PM
vtec69's Avatar
Default t-belt question
I just installed a new timing belt on my ls/vtec and tightened the tensionor down to specs and the top part my the cam gears has a little slack.
Is it suppose to have some slack?
What can i do to tighten it if nots suppose to have slack?
Thanks in advance
-Brian
Also does anyone know whats suppose to go in this hole? ITs located in the block on the intake side on the bottom by the distrubter.
[img]http://www.imagestation.com/picture/sraid38/pe70eb89a4b75a53bfb5cb9bbe4b02886/fd0ddf2f.jpg[/img
Old Nov 11, 2002 | 10:24 PM
Jai SI's Avatar
Default Re: t-belt question (vtec69)
Well I don't know exactly how to tighten it, but I do know that it needs to be tighter than that. Was there a spring that you took out when taking if off? If that little spring was missing then I might be causing the looseness. But then again, I'm not sure if it needed a spring, haven't done a tming belt on an LS yet. Sorry couldnt help more.
Old Nov 11, 2002 | 10:30 PM
Tofurky's Avatar
Default Re: t-belt question (Jai SI)
you sure you have the right timing belt?
Old Nov 11, 2002 | 10:32 PM
Ivan's Avatar
senior gold member
okay let me see if I remember. Before you tighten the tensioner turn it a little and then tighten it. Let me know if you understood me?
Old Nov 11, 2002 | 10:33 PM
B18EG6's Avatar
ya missed one
Old Nov 11, 2002 | 11:35 PM
IntegD's Avatar
New User
Top shouldnt have that much slack. Timing belts are a bit tricky usually. I have done like 6 or 7 with friends and maybe once or 2 times it goes on perfect and tensioner just pulls everything perfectly tight. Just did two this weekend, did them both the same ghetto way, and both work just great.
Whats the ghetto way you ask? Sure I'll tell you. The tensioner will tighten the right side of the belt(water pump side), so when putting the belt on....put the left side of the belt on first and make sure that side is tight and then slip the other side of the belt on. When you tighten the tensioner, the water pump side should get pretty tight. Ghetto tip: Have a friend push up on the tensioner and then tighten it. This will help make sure the belt is tight. The top usually becomes tight when the belt is installed right. If you need to, turn the crank where its a little off so when you put the belt on, you can turn the crank to tighten the left side of the belt. It might be hard for you to get what I am trying to describe, so just post up if you have any questions. Good luck bro....
[Modified by IntegD, 12:36 AM 11/12/2002]
hmoobhero
Mar 4, 2011 02:33 PM
Teamdiesel
Apr 21, 2008 05:28 AM
vtec69
Nov 12, 2002 07:21 AM
vtec69
Nov 11, 2002 10:25 PM
KayOs
Aug 15, 2001 12:16 AM
