t-belt question
Old Nov 11, 2002 | 07:41 PM
vtec69's Avatar
Default t-belt question
I just installed a new timing belt on my ls/vtec and tightened the tensionor down to specs and the top part my the cam gears has a little slack.
Is it suppose to have some slack?
What can i do to tighten it if nots suppose to have slack?
Thanks in advance
-Brian
Also does anyone know whats suppose to go in this hole? ITs located in the block on the intake side on the bottom by the distrubter.
[img]http://www.imagestation.com/picture/sraid38/pe70eb89a4b75a53bfb5cb9bbe4b02886/fd0ddf2f.jpg[/img
Old Nov 12, 2002 | 07:03 AM
eh-D's Avatar
Default Re: t-belt question (vtec69)
I'm going to give you a free TTT, and also add that I'm pretty sure the belt should have more tension than that, and I think the hole you are asking about is for a freeze plug.
Old Nov 12, 2002 | 07:21 AM
Sleeper's Avatar
Roll the engine over by hand and get all the slack between the water pump and intake cam gear, before you tighten the tensioner.
The hole is where the stock breather tank resides. You can get a plug for it from Endyn(www.theoldone.com)
Spawne32
Aug 4, 2009 11:06 PM
DeDonDeRosa
Mar 22, 2006 12:50 PM
RCautoworks
25
Aug 15, 2004 09:17 PM
vtec69
Nov 11, 2002 11:35 PM
vtec69
Nov 11, 2002 10:25 PM
