Road car suspension/chassis advice
Hey guys, I'm just getting into the meat of my 6th EG Civic build. This one is a daily driver that I'm putting about 120mi/day on going back and forth to work (mostly highway). This car will never see a track, but I have some fun windy roads on my commute.
Where weight is concerned, it will have a D16 engine (no AC or PS), I have a couple subs in the back, and it has Integra brakes front/rear. So it's slightly heavier than stock on a CX shell.
Wheels are 15x7F with 195/50/15 & 15x8R with 195/50/15 Falken Ziex tires.
I'm currently on KYB struts with Eibach Pro lowering springs. I have an Integra rear sway bar (14mm?) and aftermarket LCAs in back. Front strut-tower brace. Otherwise suspension/chassis is stock.
I also have a set of K Sport Kontrol Pro coilovers that I have not installed because the spring rates seem quite high... feel free to comment.
I enjoy the way the car feels in terms of handling bumps on the road, but I want to reduce body roll and increase traction while accelerating.
Traction bars? Bigger sway bars? Coilovers? Experienced input is appreciated.
Cheers
Cheers
all of the above, with the addition of a rear subframe brace if you plan on running a larger rear swaybar. stiffer struts/springs being the best help available to you. why the staggered wheels?
The staggered setup combined with running the same size tire front/rear allows me to firm up rear end roll (slightly) which should improve turn-in.
That's the idea anyway, and I may decide to run a square 205 setup instead if I still don't end up with enough grip up front. Wheels are Enkei RPF1 to keep weight gain to a minimum.
on my dedicated road track car i run 15x7 with 205/50 tires. traction bars, PIC select coils, large front and rear swaybars, a rear brace (large diameter can actually tear the subframe). you can start corner balancing with your coilovers installed, which can be a game changer.
your corner balancing efforts are yours, every car is different. asr makes a good brace, anything you can afford other than knockoff crap will get the job done.
mmag2982
Jun 19, 2015 11:08 AM
herrgolf
Jul 29, 2011 09:47 AM
