Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
Built High Comp Type R Longblock.
Old Dec 4, 2017 | 01:24 AM
Z0831xiz's Avatar
Default Built High Comp Type R Longblock.
Setup is a 01' B18C5 block & Head
550cc Deatschwerks injectors
ITR intake manifold
AEM fuel rail & FPR
AEM true time cam gears
Skunk2 alpha 70mm TB
Skunk2 tuner 2 cams
Skunk2 alpha dual valve springs & retainers
Skunk2 LMA's
ITR OE Valves
Mugen Power 4-1 high flow header
Gates racing timing belt
Cp Pistons 12.5:1 compression
BC LW H beam rods
89MM OE Stroke Crank
Golden Eagle oil jet delete
Golden Eagle Block gaurd
ATI Superdamper street
ACT 9lbs flywheel
ACT HD press plate & clutch
NGK spark plug & Wires
New OE Headgasket
New OE Water pump
New OE Oil pump
New OE tensioner
ARP main studs
ARP headstuds
ARP flywheel bolts
ARP pressure plate bolts
ARP tensioner bolt
ARP Crank Damper bolt
Cams have been degree'd by Redline performance in DFW also machine work on block done by AMS in burleson.
have paper work to done & everything else under my name. am located in dallas. pictures should give good detail as to conditions of the engine will take serious offers from running Cars to cash offers. everything on the short block is new with 0 miles.
Z0831xiz
Dec 9, 2017 04:34 PM
89si-rex
Jul 3, 2013 07:07 PM
jdmxtacy
Jan 26, 2005 08:35 PM
Gatweb
Nov 5, 2004 10:09 AM
