B18b1 into del sol
Hey guys, so I have my 1995 Acura Integra LS and my 1994 Honda Del Sol D15B7. I pulled the D15 and B18B1 out of both cars and have fully rebuilt my B18 with Wiseco pistons, Manley H beam rods, king bearings, fully built head, springs, retainers, valves all that good stuff. So, moral of the story is that I’m swapping my B18 into my del sol and need some help understanding how to connect my wiring harness from the B18 into my existing harness in the del sol. How and what will I need? (It is going to be turboed aswell)
it's PLUG AND PLAY, including the P75 ECU. The only thing you will need to buy (that is not usable from the Integra) is the shift linkage. Order/pick up one from a DOHC VTEC Del Sol. You will need both rods along with the shifter.
will tho original shift linkage from the del sol work? Or do I have to get the one from the VTEC del sol?
1. DOHC VTEC DEL SOL shift linkage and shifter
2. ACT/Exedy/Competition Clutch kit
3. miscellaneous parts such as throw-out bearing, rear main seal, water pump, timing belt, valve cover gasket, etc....
4. MTF
Hey guys, what size turbonetics turbo will be best in my fully built b18b1? I don’t want it too big and I definitely don’t want it too small (different brand turbo suggestions are more than welcome)
swap is already complete, fully built block and head, darton sleeves,Wiseco pistons 8:3:1 compression, Manley H beam rods, Supertech springs, valves and retainers, Skunk2 ultra series intake manifold and throttle body. Also Just ordered blox B series swap shift linkage for my del sol. Along with hondata s300. I’m looking for a good turbo for the set up nothing over 800$ for turbo alone. Planning on getting TIAL BOV and wastegate
making 686 HP to the wheels and 590 TQ with sleeved block and 6262 precision ceramic ball bearing turbo and still turnin it up.
00blackcivic
Oct 28, 2021 08:31 PM
ToPNoTcHTeChNIk
Apr 30, 2009 04:28 PM
