Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
CAr stalls with lights on
Old Nov 27, 2017 | 05:09 PM
Demoncar's Avatar
Default CAr stalls with lights on
I’ve got a 2001 civic, standard transmission. Had some issues with the alternator a while back but after putting in an alternator and fresh battery I think that issue is solved. The car starts up fine and drives but suddenly stalls and then won’t turn on again sometimes for 24 hours. All the dash lights come on and car goes totally dead. Seems to happen more often than not when the vehicle is warmed up and the lights are turned on. Lights can be turned on or off when the vehicle first starts running without issues. I’ve checked the ignition as it seems to be a known issue and rechecked my alternator bolts after noticing a bulletin on it. I don’t have access to a code reader at home but my final guess is this thing needs either a new fuse block or an exorcism or both. Anyone have any other ideas?
Old Nov 27, 2017 | 08:23 PM
toyomatt84's Avatar
Sanji
Default Re: CAr stalls with lights on
Have you checked the engine grounds? Also, most auto parts stores will scan codes for free.
Old Nov 28, 2017 | 12:43 PM
holmesnmanny's Avatar
did you get the alt from a parts store ?
robycivic
Apr 26, 2017 11:17 PM
Javier Ahumada
Jan 16, 2016 06:48 PM
Ghett0_ed
Jun 22, 2010 01:39 PM
justinwebb
Mar 9, 2009 11:45 AM
Puro Zacatecas
Nov 27, 2008 05:33 PM
