97 civic - high pressure in coolant system
Old Nov 27, 2017 | 02:35 PM
O Riley's Avatar
Default 97 civic - high pressure in coolant system
I have a 1997 Honda Civic ex 1.6l we've replaced all hoses and the motor was rebuilt 4 months ago but the top main radiator hose has alot of pressure and it has popped off the radiator it will over heat and the guage goes back to normal when the car is slowed down as Soon as speed gets back up the guage goes up we can't figure out what's going on with it could I have some input please thank you
Old Nov 27, 2017 | 02:38 PM
O Riley's Avatar
Default re: 97 civic - high pressure in coolant system
We started replacing hoses when one busted on us and then another so we replaced all of them but now there is alot of pressure on the top radiator hose and we can't figure out why
Old Nov 27, 2017 | 03:12 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
compression test, leak down test and block tester test (blue fluid goes yellow)
Old Nov 27, 2017 | 04:59 PM
O Riley's Avatar
Icon3 Re: 97 civic - high pressure in coolant system
Ok could you tell me why when we start it up and take the radiator top off the antifreeze comes pouring out of the radiator
Old Nov 27, 2017 | 05:55 PM
mk378's Avatar
Default Re: 97 civic - high pressure in coolant system
That happens because the head gasket is blown or there is a crack in the head or the block. Air and exhaust from the cylinders blows through the leak and pushes the coolant out of the engine.
There should be no action in the radiator when you start the engine up cold with the radiator cap off. (Do not take the cap off while the engine is hot. Do this test only with it completely cold.)
Old Nov 27, 2017 | 05:56 PM
pityocamptes's Avatar
Thermostat stuck shut? Bad radiator cap?
Old Nov 27, 2017 | 06:14 PM
O Riley's Avatar
Ok thank you and we will have to change that out
skiracer8148
18
May 14, 2019 06:22 PM
Dolan Commoss
Mar 16, 2019 01:59 PM
Jimi Hondrix
Mar 5, 2017 05:21 PM
Koko4
63
Aug 11, 2015 01:08 PM
mattthethug
Aug 31, 2010 04:03 PM
