Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
BMXA Whining Noise - Valve Body related?
Old Nov 27, 2017 | 09:04 AM
hgufrin's Avatar
Default BMXA Whining Noise - Valve Body related?
Hi,
My 2003 Civic with BMXA was stuck in park with a whining noise; absolutely would not move. I have pulled and disassembled the transmission. The clutches all look good. ( I will replace anyway). The filter was not completely clogged like I thought it would be ( I will replace anyway). None of the steels are burned (I will not replace). There was very minimal debris and dirt inside of the case (subjective, I know)... I will also replace the torque converter.
Can you tell me where to look next? Should I pull ALL of the valve bodies apart? What do I look for... Just dirt? Are there O-rings inside of there needing replacement?
Im kind of thinking that my only issue is the torque converter...
I sure would appreciate your help.
deerman2701
Jan 6, 2012 06:54 PM
sector001
Oct 13, 2006 12:09 PM
MrEg
Oct 13, 2003 04:47 PM
Nizzy
May 17, 2003 03:14 PM
Luke
Feb 17, 2002 09:26 AM
