94 accord question about vss.
Old Nov 25, 2017 | 01:05 PM
wwolf771177's Avatar
Default 94 accord question about vss.
So my speedometer stopped working. I've done troubleshooting and I've searched online.
CEL is on.
I've changed the speed senser and I've changed the cluster.
I've confirmed the gear in the tranny moves when the tire moves.
Ive disassembled the gear shaft clean it and made sure everything rotates.
Now my question is can the vss gear shaft go bad?
Any other troubleshooting tips?
Should I get a whole new vss and gear shaft?
TIA
Old Nov 25, 2017 | 03:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 accord question about vss.
What is the code that is stored causing the CEL to come on?
Jumper the two wire blue connector under the glove box door.
Turn ignition to II(ON).
Watch the CEL and D4 for blinking.
Record code(s).
Report back here.
Old Nov 25, 2017 | 03:40 PM
Record code(s).
Report back here.
I should have mentioned I have a manual transmission. No D4 light.
Old Nov 25, 2017 | 06:28 PM
angrysmileyface's Avatar
Are the pins in the vss harness connector intact? Does the harness have continuity?
Old Nov 25, 2017 | 07:07 PM
Yes and yes. Tomorrow morning in going to test the orange wire at the harness that connects to the cluster. I'll keep you guys posted.
Old Nov 26, 2017 | 07:36 AM
Then what cel do you have. Regardless of d4 being there or not
Old Nov 26, 2017 | 07:45 AM
So this morning I checked the connector of the vss between blk and orange for pulse readings and I got a steady 4.7 volts. Not pulsing at all when spinning the wheel.
Then I went to the 16 pin connector at the cluster for the speedo and the same constant 4.7 v from ground to orange wire while the vehicle is in motion.
Since the voltage wasn't pulsing then the sensor is bad correct?
I got a sensor from the junk yard but what are the chances I got a another bad sensor....
Old Nov 26, 2017 | 09:13 AM
Bad sensors are common. Civics from this time period used the same ones. Don't cheap out if you can go find an oem
iamtwan
Oct 12, 2012 10:33 PM
H22 EG Dude
Nov 14, 2010 12:41 PM
slickster
Jul 6, 2008 08:01 PM
SikAuto
Jun 1, 2008 07:07 PM
tat2ooed
May 3, 2008 03:02 PM
