where is this part located
Old Nov 24, 2017 | 01:32 PM
cluda's Avatar
Default where is this part located
my 1997 honda accord lx 2.2 4cyl.(not the vtech) automatic. the code p0715 came on and need a better descibtion on locaction so i can find it
Old Nov 24, 2017 | 02:35 PM
Accordian47's Avatar
10 Year Member
Default Re: where is this part located
Looks like a code for an automatic transmission speed sensor. "Input/Turbine Speed Sensor" its being referred to as.
This is what it looks like:
Heres a link to a YouTube how-to video for the 97-02 Accord input/turbine speed sensor replacement:
The sensor is mounted somewhere on the outside of the transmission so its not like you need to take your whole transmission apart but you will need to remove a few minor things to gain access.
Old Nov 24, 2017 | 02:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That trouble code refers to the Mainshaft Speed Sensor circuit. It is located on the transmission, under the battery area.
The issue can be due to the PCM, transmission, mainshaft speed sensor circuit, or an engine problem. There was a Honda service bulletin regarding it before.
File Type: pdf
madnad
Sep 18, 2018 06:49 AM
thezafarkhan
Transmission & Drivetrain
May 8, 2017 05:50 AM
jsawright
Feb 22, 2010 11:39 AM
guyuenvy
Apr 30, 2002 09:59 AM
