90 wagon cooling issues?
Old Nov 23, 2017 | 12:20 PM
HkhPatriot's Avatar
Default 90 wagon cooling issues?
1990 civi wagon temp gauge issues? So for some reason my temp gauge seems to only either want to work when it's at a dead stop or it has something wrong. Under normal driving and after it is warm it only slightly rises and I'm talking hardly but seems like it raises a little bit. It has coolant and would assume it's not the thermostat since it is getting cooled down, when stopped like parked or in traffic it does its but maybe to 1/4 of the way just about every cold. But once I drive it goes back down. Is this common or maybe my gauge over the years has just moved out of position or something? Has a full sized radiator not a half size and not too sure if the fan works I'm assuming no since it dose the get hot enough to turn on or something. If somebody could give me some feedback or tips or something that'd be great!
Old Nov 23, 2017 | 01:22 PM
2x0's Avatar
2x0
10 Year Member
Default Re: 90 wagon cooling issues?
Thermostat probably is stuck open, that’s the first thing to replace.
Make sure it is full of coolant too.
Old Nov 23, 2017 | 08:38 PM
Marcos Barrios's Avatar
oh yea thats most likely what it is
the thermostat is either stuck open or not in there at all
the gauge sounds like its working
Old Nov 25, 2017 | 05:08 PM
acmoc's Avatar
Mine did this too It was the sensor that goes under the dizzy in the head. It needs to be oem honda. Third party are not correctly calibrated.
eddie7978
Mar 22, 2018 08:33 AM
acc0rdf22
Apr 11, 2010 03:05 PM
meanshyguy
Aug 24, 2008 07:50 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
B00STED Si
Jun 16, 2005 08:26 AM
