OBD 1 location for 92 Honda Civic
Old Nov 20, 2017 | 10:55 AM
Mr.Fox's Avatar
Default OBD 1 location for 92 Honda Civic
I have googled and watched videos and I have no clue where to look for the OBD 1 code reader. My Honda would sometimes get signals to the fuel pump and other times it wouldn't. We traced it down to the fuse box under the steering wheel and replaced it but we're still having the same problems. Does anyone know how to fix this?
Old Nov 20, 2017 | 11:56 AM
egsleepercivic's Avatar
Default Re: OBD 1 location for 92 Honda Civic
Check this homie
https://honda-tech.com/forums/honda-...lists-1901557/
Old Nov 20, 2017 | 01:02 PM
mk378's Avatar
When the fuel pump does not always run when the key is turned on, leading to a cranks but no start situation, the prime suspect is the main relay. There are articles all over the web about how to remove and resolder your main relay. Anyone with a 1995 or earlier with fuel injection should do this even if they aren't currently experiencing problems.
The main relay failure will not set a code. But it is good to know how to read codes anyway.
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
yossi6780
Jul 25, 2014 12:09 PM
gamakichi77
Apr 21, 2009 09:47 PM
ls92hatch
Jul 18, 2007 10:44 AM
B18 CYA
15
Sep 16, 2006 12:04 PM
