1996 Honda accord cranks no start
Old Nov 20, 2017 | 05:51 AM
Nigh8t's Avatar
Default 1996 Honda accord cranks no start
Car was working fine until I changed heater hose I also took off distributor an ignition cable an the distributor was on but ignition cable was off wen I cranked it I changed all cables it still wont start pump primes but CEL stay on just cranks could someone help please
Old Nov 20, 2017 | 09:04 AM
holmesnmanny's Avatar
Default Re: 1996 Honda accord cranks no start
scan for codes and be sure the distributor connectors are all the way clicked in
Old Nov 20, 2017 | 10:10 AM
Nigh8t's Avatar
I check all plugs everything is hooked in
Old Nov 21, 2017 | 02:37 PM
check all your fuses in the engine bay and drive side kickboard fuse assemblies, make sure the intake manifold ecu ground is attached
sharaaz2001
Nov 18, 2016 04:01 AM
Ashley Shults
Nov 14, 2016 09:51 PM
Kevin1540
Sep 4, 2013 01:51 PM
bxny
Apr 30, 2011 12:56 PM
