replacing the catalytic converter
Old Nov 11, 2002 | 06:02 PM
tegracr's Avatar
Default replacing the catalytic converter
i just got my high flow cat in today for my 97 gsr and went out to try and remove the old one and i couldnt get to all the bolts. they are behind brackets and i couldnt get a wrench in there to get them off. have any of yall put in a new cat. if yall have can yall give me some suggestions or tips. if yall have a link to a article where they took one off that would be great to. Thanks.
Old Nov 11, 2002 | 06:17 PM
tegasaurus's Avatar
Default Re: replacing the catalytic converter (tegracr)
i have a craftsman tool set, and the small socket wrench fit in there, then i took the handle-bars from my old bike, bent them around a little bit, then used that as a breaker bar.
you jsut gotta be creative when building tools haha. Something that might help out is if you unbolt your cat from your header, then unbolt the axle back portion and take it out in one piece (cat to axle pipe, and cat) then disconnect the cat from there, then re-attach your hi-flo one and do reverse order! any more questions IM me
hope i helped,
Ryan
[Modified by tegasaurus, 7:19 PM 11/11/2002]
Old Nov 11, 2002 | 06:18 PM
KOALA YUMMIES's Avatar
Yall should pull off the heat sheild yo. Then yall be able to access the last 14mm bolt. Or yall could undo the hangers on the b-pipe and undo the header collector bolts and then pull the exhaust down and yall should have access to the last bolt. Good luck yall.
ROFL!!! \/ \/ \/ \/
[Modified by NOINTEGReddy, 3:39 AM 11/12/2002]
Old Nov 11, 2002 | 06:33 PM
tegasaurus's Avatar
Default Re: replacing the catalytic converter (NOINTEGReddy)
yall come back na, ya he-yer?!
[Modified by tegasaurus, 7:36 PM 11/11/2002]
Old Nov 11, 2002 | 06:51 PM
tegracr's Avatar
Default Re: replacing the catalytic converter (tegasaurus)
im gonna try again tomorrow wit a little better socket set and see how it goes. ill let yall kno how it goes.
Old Nov 11, 2002 | 07:28 PM
ActionJackson's Avatar
man you beat me to it!
Old Nov 11, 2002 | 07:34 PM
SIK IN DA HED's Avatar
New User
get a good set of socket wrenches and eat some protein bars.
Old Nov 12, 2002 | 12:38 AM
slomob18b's Avatar
bolts on the cat are a b!tch to take off. on one side i used a ratched and the other side i used a socket wrench. i had to use them at the same time. so on one side i would be pushing on the socket wrench and on the other i would be pulling on the ratchet. pain in the ***..
Old Nov 12, 2002 | 02:02 AM
IntEGNYC's Avatar
Default Re: replacing the catalytic converter (ActionJackson)
Holla!
AZNracerx1989
Apr 18, 2023 05:30 AM
project91crxsi
37
Aug 16, 2009 07:35 AM
shadowdawn
Jun 26, 2004 12:30 PM
Halo
Jul 14, 2001 08:50 AM
