Vtec to ulev swap help!!!!
I have a 98 accord 2.3 and tranny went. I purchased a crashed 02 accord with a ulev 2.3 and swapped motor and tranny into my 98 accord.
Car runs good. Temp gauge isn’t working and car isn’t reading o2 sensor. Keep getting p1035 code.
Ulev motor doesn’t have the temp sensor on side of head. I took sensor off old motor. Which wire yellow and green wire do I tap into to get temp. Signal and how do I go about getting o2 to read. ?? I have ecu from the 02 accord but I junked the car before i can take out immobilizer. What should I do. Thanks
F23A4 engines were ULEV (Ultra Low Emission Vehicle). F23A1 were generally non-ULEV.
I believe both F23A1 and F23A4 were SOHC VTEC engines. The ULEV engine was similar to the non-ULEV, the main differences were the exhaust manifold, a more restrictive intake manifold and cylinder head, and the PCM/ECM.
You should be able to swap the exhaust manifold and intake manifold from your previous engine on to the replacement engine and use your current PCM. If you use your current PCM, there is no need to reprogram it for to the Immobilizer System (if you replaced the PCM, reprogramming for the Immobilizer will be necessary unless it was bypassed/disabled.)
There were some differences in models years between 98 and 00.
Differences in model years (not because of ULEV vs. Non-ULEV)
Wiring for temperature gauge slightly different.
1998-99 Accord: Engine coolant temperature signal is from coolant temperature gauge sending unit. 98-99 Accord had Yel/Grn wire from coolant temperature gauge sending unit to Gauge Assembly Connector pin C2.
2000-02 Accord: Engine coolant temperature signal is from PCM. 00-02 Accord had Yel/Grn wire for Engine coolant temperature signal from PCM Connector pin C24 to Gauge Assembly Connector pin C2.
Difference between ULEV vs. Non-ULEV (98-02)
ULEV had Air/Fuel Ratio sensor. If you used your current exhaust manifold and PCM, you can just use the regular O2 sensors.
Sakamoto
Aug 17, 2018 11:11 AM
MysticalMagnet
Northeast (Sales)
Dec 2, 2009 11:23 AM
eauto
Oct 6, 2004 04:38 AM
