zc pistons in a d16z6
Old Nov 11, 2002 | 05:42 PM
Don Napier's Avatar
Import Alliance
Default zc pistons in a d16z6
will the zc pistons raise compression in the motor?
Old Nov 11, 2002 | 07:06 PM
Don Napier's Avatar
Import Alliance
Default Re: zc pistons in a d16z6 (egCivicDon)
Old Nov 11, 2002 | 07:43 PM
RR98DX's Avatar
yes and by quite a bit. 12:1 i heard.
Old Nov 11, 2002 | 07:52 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: zc pistons in a d16z6 (RR98DX)
it only raises the compression 1/2 a point in an otherwise internally stock engine. Mill the head and thinner head gasket and your compression can easily reach 12:1
Old Nov 11, 2002 | 07:56 PM
JaeOne3345's Avatar
Default Re: zc pistons in a d16z6 (Emerica)
i did calcs today using sonny chart and c speeds tool
zc/a1 pistons (big dome version) in a z6 yield 12:1 with no mill using the stock z6 or y8 headgasket
Old Nov 11, 2002 | 07:57 PM
Don Napier's Avatar
Import Alliance
what is the z6's stock compression?
Old Nov 11, 2002 | 07:58 PM
JaeOne3345's Avatar
9.2:1
Old Nov 11, 2002 | 08:09 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: zc pistons in a d16z6 (JaeOne3345)
Are you freakin serious??? Man, I was always told it was only 1/2 a point...those domes are definately large compared to the stock pistons
Old Nov 11, 2002 | 08:18 PM
JaeOne3345's Avatar
maybe the people you talked to were getting confused with the a6 pistons which some people use..or they meant the 86-87 pistons.
with a z6, it is 12:1 though.
Old Nov 11, 2002 | 08:19 PM
Evs-One's Avatar
Solbros Owns Me
oh, the 86-87 D16A1 pistons don't have the same geometry as the 88-89 then??
Old Nov 11, 2002 | 08:32 PM
JaeOne3345's Avatar
hellzzz no.
the 86 87 look weak as hell.
88 89 got the baby CTR mountain range on top
Old Nov 12, 2002 | 08:01 AM
Don Napier's Avatar
Import Alliance
Thanks guys...any clue on what cam will produce the most power and still be drivable everyday?
Old Nov 13, 2002 | 09:33 PM
Don Napier's Avatar
Import Alliance
Any guess on hp after the pistons are installed....with i/h/e?
Any guess on hp after the above and a cam and tuning?
Old Nov 14, 2002 | 04:32 AM
Don Napier's Avatar
Import Alliance
Old Nov 14, 2002 | 05:35 AM
JaeOne3345's Avatar
all motor sohc making big power = big cam
since u are going the vtec route (most of the fastest sohc's ive seen are non) id recommend the crower stage 3 cam with valve springs...
youd have 12:1 compression and with a cam like that i see no reason why u cant put down 160+. builthatch made 164 with a milder cam. jg made 160 on a 11:1 street sohc vtec.
did i mention SRR makes a 4.929 final drive for the sohc vtec tranny? 160+ with that tranny = one fast *** sohc in the right car
just make sure you clay the engine because the a1 pistons are non vtec, which means the valve reliefs in the piston will not match the valve location in the head
u need to go to http://www.dseries.org and stop asking these questions here, all u will get is people telling u to swap swap swap.
[Modified by JaeOne3345, 6:37 AM 11/14/2002]
Old Nov 14, 2002 | 07:28 PM
Don Napier's Avatar
Import Alliance
thanks for the info again...is the crower stage 3 cam hard to drive on the streets?
Old Nov 14, 2002 | 07:30 PM
JaeOne3345's Avatar
from what ive heard its fine on the street.
Old Nov 15, 2002 | 05:41 PM
Don Napier's Avatar
Import Alliance
ok...one last question...I have some cx pistons too...would it be faster with the greddy turbo kit I have with stock pistons or the cx ones? I know the zc's are too high of compression for a turbo application. Are the z6 and the cx pistons the same? I just cant make up my mind on what to do. Any advice?
Old Nov 16, 2002 | 06:47 AM
Don Napier's Avatar
Import Alliance
Bump
Old Nov 17, 2002 | 08:32 PM
Don Napier's Avatar
Import Alliance
CALC!_JUST_du_IT!
Dec 27, 2006 12:01 PM
hatchinprogress
Nov 23, 2005 11:27 AM
Honda Crx
Nov 3, 2005 07:02 AM
Leb_CRX
Sep 24, 2002 06:19 PM
