1994 Honda Accord EX
Old Nov 14, 2017 | 01:23 PM
BillPerry's Avatar
Default 1994 Honda Accord EX
My issue is the car wont start. New battery and starter. No clicking noises. I can push start the car and it starts. Never shuts off while driving the car. I pulled the mail fuse under the dash and then hooked it back up and bingo it starts right up. i shut the car off and then it wont start again til i remove it and re hook it up. Any ideas the problem? Thanks for any ideas.
Old Nov 14, 2017 | 02:50 PM
holmesnmanny's Avatar
Default Re: 1994 Honda Accord EX
With the car in neutral(the car must be in neutral or you could get seriously hurt), and the ignition in the start position, jump the starter with a screwdriver and see if it starts.
Old Nov 14, 2017 | 03:04 PM
BillPerry's Avatar
Starter isn't the problem. When i pull the main relay then reinstall the car starts right up. shut it off try to restart and it wont. pull the relay and reinstall and it starts right up again.
Old Nov 14, 2017 | 03:09 PM
then you need to do some testing when it's not starting, check for fuel and check for spark
Old Nov 14, 2017 | 03:13 PM
BillPerry's Avatar
When i say it doesnt start i mean the engine doesnt turn over. i have good spark and fuel pressure from just before this issue. so i know thats not a issue. when i turn the key i get all the lights and everything. just doesnt start til i take the main relay out and reinstall.
Old Nov 14, 2017 | 03:36 PM
then start with replacing the main relay, sounds like the solder points might be worn and when you take it out and put it back it cools enough to get it to work
or you could redo the contacts yourself
Old Nov 16, 2017 | 05:06 PM
tamboo's Avatar
10 Year Member
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
ILUVTEC
Mar 20, 2010 01:31 PM
ILUVTEC
Mar 20, 2010 01:30 PM
ace42004
May 24, 2007 02:28 PM
slow_redcivic
10
Apr 9, 2006 04:57 PM
fanatic
Nov 5, 2005 06:00 PM
