what kind of coilovers should i run on my 5th gen?
Old Nov 11, 2002 | 05:33 PM
Boostless97Lude
Guest
Posts: n/a
Default what kind of coilovers should i run on my 5th gen?
i've got some ground controls with tokico illuminas on my Teg, i was thinking of something simialr with my Lude.... any suggestions?
Old Nov 11, 2002 | 06:07 PM
blacklude's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (Boosted97Lude)
How much are you trying to spend?
Old Nov 11, 2002 | 06:13 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: what kind of coilovers should i run on my 5th gen? (blacklude)
hrmm... well, seeing as how a set of tokico iluminas and ground controle would run me roghly $750-$800, i be will to spend up to ~$1000
Old Nov 11, 2002 | 08:51 PM
DsITR's Avatar
I have the GC coilovers, they work great easy to adjust too.
your setup sounds great...but you might want to look into KYB AGX's they are a bit cheaper, and are still adjustable.
Old Nov 11, 2002 | 11:10 PM
Sticky Tires's Avatar
* B A N N E D *
<--- Tein SS
[Modified by VtecDialect, 3:10 AM 11/12/2002]
Old Nov 12, 2002 | 01:21 AM
buh_buh's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (VtecDialect)
Ground Controls + Koni Yellows =
Old Nov 12, 2002 | 01:43 AM
PrecisionH23a's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (buh_buh)
ground control + tokico illumina 5 way adj for me
Old Nov 12, 2002 | 06:32 AM
typeSwarrior's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (GudeH23a)
That's the route I would take right there I've heard good things about Skunk2 coilovers from a lot of my buddies who use them also. GC is what I want personally though.
Old Nov 12, 2002 | 07:07 AM
JensPanyard's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (typeSwarrior)
I've looked at the tein and the Tanabe(sp?). One bad thing is there both close to $2000.
Old Nov 12, 2002 | 07:47 AM
ludespeeder's Avatar
Default Re: what kind of coilovers should i run on my 5th gen? (JensPanyard)
Tein HA or Tein SS.
Old Nov 12, 2002 | 09:07 AM
aklucsarits's Avatar
New User
Agreed. Choose your own spring rates.
Andrew
Old Nov 12, 2002 | 09:08 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: what kind of coilovers should i run on my 5th gen? (aklucsarits)
do the koni shocks have some kind of markings or something that give a reference point??
Old Nov 12, 2002 | 09:13 AM
LJR-LUDE01's Avatar
TEIN's HA 995 shipped in a group buy a while back
Old Nov 12, 2002 | 09:25 AM
New User
Reference point for what? For rebound adjustment? For rebound on Konis, you start out turning them to full soft. Then you turn the adjustment **** towards stiff until you've found settings that you like. Just never run the car on the full stiff setting!
Andrew
Old Nov 12, 2002 | 09:34 AM
Boostless97Lude
Guest
Posts: n/a
on my illuminas on my Teg, they have marks, 1 2 3 4 5, around in a circle woth a little arrow on the adjuster to give the desired setting, that way you KNOW each shock is set the same
Old Nov 12, 2002 | 01:32 PM
blacklude's Avatar
For that amount I'd get a set of Tein SS dampers. You can get them from http://www.jaydm.com for $975 shipped.
Old Nov 12, 2002 | 02:17 PM
tonydatyga's Avatar
I'd say either GC or skunk coils w/ koni yellows. Course you could always find a good deal on tiens. It really depends on which tien line you want. I really like the rates on the skunks for dc2s but the prelude seems a but harsher. Looks like a lack of travel.
Old Nov 12, 2002 | 02:25 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: what kind of coilovers should i run on my 5th gen? (tonydatyga)
but will i need a camber kit if i drop it very far??? i have some ghetto R1s that i bought form a crackhead for like 20 bux, worked ok, they even rode decent, but i want something that i know is made well. plus, anyone got any ideas on how much i can/should drop it with 19s?
Old Nov 12, 2002 | 02:30 PM
* B A N N E D *
exactly, if i was spendin around $1000, i would go with Tein.
Old Nov 12, 2002 | 02:32 PM
Boostless97Lude
Guest
Posts: n/a
ok, honestly, are the Tein really THAT good? do they have a website or something where i can read up?
Old Nov 12, 2002 | 02:35 PM
tein is the ****, end of story. if you have the money, get them.
http://www.tein.com/
Old Nov 12, 2002 | 02:37 PM
Boostless97Lude
Guest
Posts: n/a
so simple, i never would have guessed
Old Nov 12, 2002 | 03:09 PM
csulliva's Avatar
ok, this is definately OT, but I just had to thank Boosted97Lude for making my day. Everyone should click the link in his sig. I had a rough day, and I about peed myself when I read the thread.
Old Nov 12, 2002 | 04:10 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: what kind of coilovers should i run on my 5th gen? (csulliva)
LMFAO!!!
i almost peed myself too when i read that.. hahahaha
Old Nov 12, 2002 | 04:14 PM
* B A N N E D *
Tein is straight up from Japan. It is way better than combining springs, coilovers, struts together. It comes complete! it has 16 settings.
There's an article about the Tein factory in the November issue of SCC. http://sportcompactcarweb.com/toc/
IMO, if i'm gonna spend about 1K for suspension, I'd go with the real deal.
I'm not saying GC+Koni is not a good setup. but Tein is the shizzle my nizzle! peace
