2002 Civic Si Hatchback blower motor
The blower motor in my 2002 Si Hatchback (EP3) started working intermittently a few months ago with no noticeable pattern. That was when I was still using the AC. Now that I need the heater and defroster, I was getting tired of it not being dependable because I did not want to go through winter without heat and the defroster part of the time, so I had the blower motor replaced. It worked for a week or two without any problems, but now it's off again. My guess is the blower motor was not the real problem and now I am out the price of the that repair. So what else could it be? I haven't been able to figure out if there is a relay that could be bad, or something else in the circuit.
Have you figured anything out ? Having the same problem
and did you try the self diagnose?
Turn car car off
press and hold the frost and circle turn key on
the light in the a/c should turn on release button
10 secs later the frost or circulate should blink counts the blinks and search the blinks up
I got 12 but didn’t pin point the issue yet
Turn car car off
dlmoore1959
Honda Civic (2001 - 2005)
Sep 18, 2013 07:26 PM
HondaStalker
Mar 27, 2013 11:05 AM
pmafia
May 17, 2007 06:34 AM
