Bad 2nd clutch pressure switch, code P1738, 99 Accord 6cy
Old Nov 11, 2017 | 04:41 PM
Bigskyguy's Avatar
Default Bad 2nd clutch pressure switch, code P1738, 99 Accord 6cy
How long can you drive on a bad 2nd clutch pressure switch, code P1738, 99 Accord 6 cyl? Light just came on. Transmission fluid ok, just changed recently. Transmission rebuilt about 30,000 ago, is at 233,000 miles now.
Old Nov 12, 2017 | 03:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Bad 2nd clutch pressure switch, code P1738, 99 Accord 6cy
I would inspect the wiring and if need be replace the pressure switch immediately. If the switch is leaking, replace it.
PCM uses the pressure switch as a means to determine if there is enough correct pressure and when to shift.
Old Nov 20, 2017 | 03:54 PM
Bigskyguy's Avatar
Switch was replaced, maintenance light now off and it seems to be working.
ZamboniDude
Acura TSX
Jan 20, 2019 03:40 PM
low430
Oct 28, 2014 02:54 AM
andhoova
Sep 1, 2010 01:27 AM
andhoova
Aug 31, 2010 07:13 AM
tdog1
Transmission & Drivetrain
Nov 23, 2008 07:38 PM
