Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic ex auto trans issue
Old Nov 8, 2017 | 06:31 AM
jspinelli8's Avatar
Default 04 civic ex auto trans issue
My sister has a 2004 civic ex auto and at high speeds (45-65mph) when she tries to accelerate it seems as if the car gas trouble shifting? Im not sure. But it’s as if the car is redlining at 3.5-4k rpm. The car shakes and if you keep on the gas for a few seconds it will eventualy upshift but theres obviously a problem. Im not sure what exactly it is but if anyone could help me out i’d appreciate it
Old Nov 8, 2017 | 06:52 AM
NDNV's Avatar
Default Re: 04 civic ex auto trans issue
What has been the history of ATF maintenance? If you haven't been doing a drain and fill of Honda DW-1 ATF at least every 3rd oil change, then you are behind in this service IMO. You may need to play catch up here with a 3 times drain and fill of Honda DW-1 ATF while driving in between to refresh the ATF. No flushing is advised.
Another area of stumbling or stuttering or hesitation at highway speeds is a failing EGR valve or clogged EGR ports with carbon. Some have described the symptoms of this problem as driving over washboard type roads.
Old Nov 8, 2017 | 10:29 AM
jspinelli8's Avatar
The trans fluid hasnt been changed in a while.. thanks for the info i’ll try that and see if it woks
g2xsi
Honda Civic (2006 - 2015)
Mar 28, 2013 08:53 AM
rhinoceros777
Feb 16, 2011 07:18 AM
froquejr
Transmission & Drivetrain
10
Aug 21, 2010 12:00 PM
tpod
Apr 3, 2009 03:40 PM
