JDM D15B Mini Me Swap "Code 22" Help Please
Hi,
I Have A JDM D15b W/ D16Z6 Head (Mini Me Swap) Using a P06 ECU Chipped & Converted VTEC.
The ECU Was Previously Mapped For a H22 Which i Was Running on the Mini Me Swap & Had No CEL.
I Just Recently Got it Remapped For The D15b & Soon As i Plugged it Back in, it Throws a CEL "Code 22" (VTEC Oil Pressure Switch) CEL Turns On Before i Start The Car & After I Start The Car, Never Turns Off.
I Must Say Its Running Alot Better Since The Remap, My Oil Levels Are Good A Bit Overfilled, i Took The VTEC Solenoid Off Cleaned it With Carb Cleaner & Put it back on Aswell, No Luck.
Any Advice or Opinions is Greatly Appreciated
-1995 EJ1 OBD1
-1995 EJ1 OBD1
UPDATE: Changed Vtec Solenoid & Vtec Oil Pressure Switch CEL Went Off Finally But... Now When i hit 5200rpms Light Will Come On But Will Eventually Turn Off Throughout The Day..
LikeAboss
May 4, 2012 12:14 PM
