Which power steering pump for GSR swapped del Sol?
Old Nov 6, 2017 | 08:18 AM
Curlybandit's Avatar
Default Which power steering pump for GSR swapped del Sol?
Hey everyone.
I recently completed an OBD1 JDM GSR swap into my '93 del Sol Si. I thought I had the correct power steering pump (actually had two of them) which I had purchased from the swap seller and a private seller but it turns out they are both incorrect. I have the proper mounting brackets.
A new OEM power steering pump from Acura through my contact there is $900.00. You read that correctly... NINE HUNDRED DOLLARS! A scrapper piece is the only real options.
I think I remember reading that any b-series PS pump will work, such as a b18b, as long as you have the right GSR brackets, but I'm not too sure.
Any suggestions or insight? If you have any other useful info like what PS hose you need relative to the pump and the rack of the del Sol (same as EG) that would be greatly appreciate as well.
Thanks!
MikeFeuti
Dec 18, 2018 10:18 AM
Curlybandit
Sep 6, 2017 04:40 AM
superslow-oto
Feb 4, 2008 08:59 PM
CopperSol
Jan 19, 2006 12:51 PM
StreetProjectz
Mar 29, 2004 07:17 PM
