Bad Cam Shaft Position Sensor?
Old Nov 4, 2017 | 09:56 AM
bestofthe80s's Avatar
Default Bad Cam Shaft Position Sensor?
Hey all,
I have a 2001 accord 4cyl sulev. This car has had some serious electrical gremlins. Something is causing the Cylinder Position Sensor to fry itself to death over and over... I have replaced WAY too many distributors because of this. I think I have identified the issue. The Cam Shaft Position Sensor that is underneath the distributor was soaked with oil. My old dizzy was leaking oil onto it for a long time. Could that cause my short in the Dizzy?
I have tested the oily sensor and a junkyard sensor and got similar kohm readings. I can't find the desired resistance in the manual anywhere. All I can find is tolerances, not resistance.
I am so paranoid that if I replace the cam shaft sensor and the distributor and the distributor gets fried again I might just freak the **** out. This **** is getting ridiculous.
Looking for any help or suggestions....
Thanks!
FreeAlchemist
Honda Civic (2001 - 2005)
Sep 23, 2017 11:02 PM
Efabe
Aug 9, 2017 02:59 PM
MinMet
May 31, 2012 05:41 PM
demo024
Honda CR-V & Element
Jan 31, 2011 12:03 AM
willpoorman
Feb 27, 2010 06:02 AM
