Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 honda civic car beep stopped and brake light on
Old Nov 3, 2017 | 05:01 PM
Webba027's Avatar
Default 2002 honda civic car beep stopped and brake light on
I checked the fuses under the hood. I will check in the car. But the fuses looked good. If not a fuse what would cause the car to stop beeping when you leave keys in door or start car? Brake light is constantly on and windshield wiper wont work on one setting and lastly car lock stopped. All at once. What could it be?
Amber
Old Nov 6, 2017 | 06:59 AM
NDNV's Avatar
Default Re: 2002 honda civic car beep stopped and brake light on
Check the brake pedal position switch. It is located at the brake pedal and Is a plunger-type switch. They do go bad.
This would not explain the wiper issue - perhaps the wiper switch or relay if the intermittent does not work?
Old Nov 6, 2017 | 09:13 PM
holmesnmanny's Avatar
wiper switch not working on one setting should just be the switch itself
https://www.oreillyauto.com/detail/d...e?q=pedal+stop
you might need to replace this at the brake pedal to fix your brakes, a lot of times it cracks and falls to the floor
Old Nov 7, 2017 | 04:36 PM
Webba027's Avatar
they all stopped working at the same time which was super odd. I will post what i find. I havent had time.
g8rdude
Mar 27, 2024 03:08 PM
Joetxstate
Mar 4, 2020 05:37 AM
Z20rider
Nov 30, 2015 07:21 AM
riznup23
May 3, 2010 05:55 AM
haz19
Oct 23, 2005 01:14 PM
