Breather heater hoses
Old Nov 3, 2017 | 02:53 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Default Breather heater hoses
Part numbers are; 19528-PM6-000 & 19527-PM6-000 both are No Longer Available.
#9 & #11 in the picture
Needed for a 1990 Civic Si.
Anyone know where to get these? Is there a substitute hose from another car that might fit well? I would settle for molded after market hoses but I would really like to avoid using generic straight hose.
Old Nov 3, 2017 | 05:04 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Breather heater hoses
Both are available on Amazon.
Old Nov 4, 2017 | 01:10 AM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
I think Amazon lists every single part number for my Civic. When it is unavailable from the Honda Dealer and Amazon says that it is "temporarily out of stock" all I ever get is an email three weeks later apologizing that they are unable to fill the order.
Both of those part numbers are "temporarily out of stock" at Amazon.
It just gives you false hope on these discontinued parts, kind of cruel actually.
Old Nov 4, 2017 | 04:03 AM
DaX's Avatar
DaX
Loved
Community Favorite
Gotcha...I just saw that it had the 'Add to Cart' button. See if your local auto parts store will let you go behind the counter and browse through the molded hoses...the guys at my local store were friendly enough to let me do that. Take the old hoses with you if you have them. You may get lucky and find something that will work. Don't forget to look at ones that may have the correct hose diameter and bend angle, but may be longer or have multiple bends...you can always cut the new hose down, or cut the one bend that you need out of the new hose. If you still strike out, your best bet is the generic hose that you said you don't want to use. If you're trying to use generic hose on a tight bend, don't try to follow the original path of the hose, because the tight bend will kink the hose. Instead, use a much longer piece and bend it in a loop so that it doesn't kink, if that makes sense. This is what I've done when I can't find a molded hose that will work.
Old Nov 6, 2017 | 05:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
Amazon is usually BS unless they state "In-Stock". Even if the parts are available via the dealer network, they may cancel your order if their price was "Too Good". I ordered a 2012 Odyssey leather seat cover from them that was listed $100 below OEMAcuraParts. After 4 months, Amazon finally cancelled the order stating "lack of availability"........,yet OEMAcuraParts said they could get it no problem.
For those hoses, you should submit an inquiry over at Amayama.com to see if these parts are still available in Japan. Their parts networks may still have them in stock. I just bought all these small hoses for my 89 Si two years ago through them.
Old Nov 6, 2017 | 06:39 AM
DaX's Avatar
DaX
Loved
Community Favorite
Good info to have...never knew about that!
jonathan rose
May 5, 2019 12:01 PM
jptra
Honda Civic (2006 - 2015)
11
Jun 13, 2015 06:32 PM
DennisWaller
Dec 14, 2008 08:14 PM
90_Si
Classic Hondas
Jul 15, 2007 02:14 PM
