Rear Harness Connector
Old Oct 31, 2017 | 08:11 PM
Cucaz24's Avatar
Default Rear Harness Connector
Hi i have a 91 civic hatchback. Got it from a friend for dirt cheap, with a b16a swap. Dogs got into it and chewed up the wire harnesses, but i was able to get an si rear harness and a crx si cabin harness. I connected everything i could together, and its a crank no start, cause the fuel pump isnt getting any power.
I have this one connector that, when i give power to the yellow/black wire with a power probe, turns on the fuel pump, i just cant figure out where the connector connects to.
Old Nov 2, 2017 | 11:18 PM
crx_si-r's Avatar
Default Re: Rear Harness Connector
by the looks of it, appears like the one above the fuse box. keep in mind 88-89 and 90-91 have different rear harnesses
BigbamaBen
Apr 29, 2012 08:11 PM
carbonlaced
Mar 29, 2006 04:32 PM
