Iacv
Old Oct 30, 2017 | 05:15 AM
Ridinlow_civic's Avatar
Default Iacv
So i have a 97 civic dx 5 speed. I recently did a intake manifold swap aswell as the tb from a y7 to a y8. My iacv were 3 wires and i changed them to a 2 wire at the connector point, at the ecu pinout i remove the orange(a13) wire and moved the blue and black wire i moved from a14 to a12. The car starts and idles normal but my issue is when i give it gas it jerks, engine is not shaking or anything. But my check engine light did pop out for the code p1509.
Can anybody give me some info on what i could do, thanks.
Old Oct 30, 2017 | 05:25 AM
mk378's Avatar
Default Re: Iacv
You also need to swap in an EX ECU, and that requires a VTEC engine. The only OBDII ECU that can run a 2-wire IACV is the manual EX one.
Old Oct 30, 2017 | 06:30 AM
Default Re: Iacv
Ohh no wonder, thanks man i really apreciate it.
Old Oct 30, 2017 | 02:39 PM
Default Re: Iacv
From what year to what year will work for the ecu?
Old Oct 30, 2017 | 06:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Iacv
1996 to 1998 Civic EX ECU... although if you didn't do a cylinder head swap, this will cause additional VTEC codes since the ECU will be looking for those sensors and all you have done is change the intake manifold and throttle body.
Old Oct 31, 2017 | 04:32 PM
Default Re: Iacv
Ill be doing a cylinder head swap soon, but for the moment if i swap the ecu will this codes affect anything or should it be fine?
Nice!! Ill get there hopefully.
hondah
12
Jun 14, 2019 08:16 PM
Metalzone
Honda Civic (2001 - 2005)
16
Aug 3, 2015 12:04 PM
DylRamos
12
Mar 28, 2013 04:45 PM
Drew96EJ
Sep 23, 2003 01:49 PM
