1992 Integra Sat for a while
Old Oct 29, 2017 | 04:54 AM
tegguy's Avatar
Default 1992 Integra Sat for a while
Alright guys I need some help here. I have a 92 Integra with a B16 in it and the car has sat for a few years becuase when I was in college it got the passenger side water leak and a lot of water got inside and it wasn't my primary vehicle. The ECU died during this period (unsure if it was due to the water or not) but that just compounded things. Life got in the way and the Teg sat in storage. I swapped the ECU at some point and it ran for like 5 minutes before the ECU blew again (large cap).
Fast forward to today I'm trying to get it up and running so I can sell it and I have some issues. I bought a new ECU for it and the car starts and runs but the following issues are happening...
1) CEL on solid but will not show a code when jumpered
2) Car is idling at 2500 RPM
3) when I press the gas pedal the car has a huge hesitation at first but then responds
I tried cleaning the IACV and injectors and that didn't help so I'm looking for more ideas......
Old Oct 29, 2017 | 04:36 PM
tamboo's Avatar
10 Year Member
Default Re: 1992 Integra Sat for a while
sounds like a code 0 (bad ecu)
OBD-1 ECU Codes
Old Oct 30, 2017 | 01:47 AM
tegguy's Avatar
OBD-1 ECU Codes
I was afraid someone was going to say that guess I have to find another p30 ecu
Old Oct 31, 2017 | 07:27 AM
CandyRedRC46's Avatar
How did you clean the injectors?
Old Oct 31, 2017 | 07:57 AM
tegguy's Avatar
pulled them out activated them with 12 volts and sprayed carb cleaner through them
Old Oct 31, 2017 | 09:05 AM
Maybe they could use a good ultrasonic cleaning.
Old Oct 31, 2017 | 11:50 AM
tegguy's Avatar
This would only solve the hesitation correct?
Old Nov 1, 2017 | 04:55 AM
It could possibly solve a lot of things.
tegguy
Apr 15, 2018 07:14 AM
RipCurl
12
Apr 5, 2007 01:22 PM
MeanieMe
May 9, 2005 11:43 AM
racerxadam
Jan 13, 2002 08:37 PM
