B16a2 intake manifold question
Old Oct 27, 2017 | 04:35 PM
Jdm2dr21's Avatar
Default B16a2 intake manifold question
So I had a question I put my b16a2 swap in my EK hatch and there's a port open on the intake manifold where the cruise control hose goes but since I don't have cruise control my question is can I cover it and close it off or do I puts a hose on it leading somewhere. When it's open it idles high and when I cover it it idles normal. And info would help thanks.
Old Oct 27, 2017 | 05:48 PM
1999 Civic Si's Avatar
Default Re: B16a2 intake manifold question
If you don't have cruise control then just cap it. You can get a multi pack of vacuum caps from most auto parts stores. Leaving that open is just causing a small vacuum leak which is causing your higher idle and letting unfiltered air in.
Old Oct 27, 2017 | 06:26 PM
Jdm2dr21's Avatar
ook thanks I just wanted to ask before I did anything.
e0325
Sep 6, 2014 06:20 PM
5exy_Ek
18
Oct 26, 2010 04:56 PM
CSHornet60
Mar 9, 2007 06:00 PM
slim689
Mar 9, 2007 10:19 AM
