updated pics of my hatch... good lookin???
waiting the christmas vacation so i can swap my all motor ls/vtec... and so i can put the pics here... but tell me what do you think of my hatch now????
hope you don`t hate....
Looks clean, pretty low.... Gonna be nice once u do the swap. I am hopefully picking up a 92 this week. For "REAL CHEAP"... I cant wait..
I like it, its clean, and the wheel covers look dope.
The mid-wing looks pretty cool too.
The only thing that Im not really feeling is the painted mirrors, and door handles. Dont know if you have side trim or not but if its painted then I dont really like that either. Its just little things, but all in all I like the car.
Good job.
Good job.
the wheel covers are 15 mounted on 14 inch wheel so it looks nice then (lots of sanding thouh)
here are mi engine mods to share with you
it`s a ls/vtec
b18A block
b16A head
y1 tranny
arias 12:0.1 cr forged pistons
oliver chrome moly custom made rods
clutch net 2800 lbs pressure plate with an ACT 50/50 disc
type r oil pump
type r water pump
stage 3 crane cams
crane dual titanium springs and retainers
all pistons, rods, crank, pressure plate, flywheel, damper got balanced
the block is bored, so the pistons fit
the head is fully built milled @20 and ported an polished
matched intake manifold with gsr t body bored @65mm
dc jdm 4-1 ceramic coated header
focuz cam sprokets
jacobs electronics ignition system
msd fuel pump
vortech fuel pressure regulator
magnecor competition series spark plug wires
maybe i forgot something don`t know...
it`s a ls/vtec
b18A block
b16A head
y1 tranny
type r oil pump
type r water pump
stage 3 crane cams
focuz cam sprokets
msd fuel pump
where can i get those wheel covers??????????? i love those things. i must no, please tell me. where can i pick up a set of steelies for cheap too?
i got the steelies from my friend at charlie rent a car 100 dolars for all with bridgestone potenza tires
and the hubs are from a honda dealer 90 bucks for all...
sanding spent time = 3 hours
job =
hey i`m in puerto rico though....
job =
what size injectors? engine management? no mention of those...oh yeah...and your stock ignition should be fine for the setup you have listed...no need to get aftermarket stuff. your hatch looks a little too low which might cause your header to scrape...
i will raise my ride a bit when i swap it (got coilovers with AGX struts)
about the injectors i have right now the gsr ones and the h23 ones.. gonna try them both to see which are better with my set up though.......
about the ignition i have it all ready... a have all the parts though just waiting for the vacations...
yeah with the z6 i ran 15.32 @ 88mph with 2.18 60 footers...
hoping to do high 12`s to md13`s with my new set up.... what do you think??
what are the cap's called? where on the net can i find them?? thanks alot, for your help in advance, how much sanding was in order? wanna sell your's?
Nice ride man. I am most likey getting my 92 hatch tomarrow (finally). It has a mid wing like that, I don't mind it, but you can see the adhesive tape and the wire for the brake light on it. I will remove it, but I don't think it looks too bad at all. As for the engine, I'm going ls/vtec as well. The hatch I'm buying already has a B18B in it. The chick took damn good care of the engine, but the exterior is a damn macco paint job, oh well.
I think those wheels would look good with light gunmetal finish. IMHO
the hubs are 2K1 ex civic model from honda dealer
and i don`t want to sell mine
hey you have to sand so they will fit to a 14 steelie (the hubs are 15`s) and a had them on 13 inch steelies before that`s why i got to sand them a lot....
, other than that.. nice ride.
