Gearbox honda so4 1998
Good day
I would like some advise please suddenly on cold start my gearbox started having a noise which doesn't sound normal but wen i apply the clutch pedal it goes away.. What could it be please advice thanx...Dominique
What kind of oil can i use
Input shaft bearings go bad after about 150,000 miles. This causes a whirring / grinding noise idling in neutral that goes away when you push the clutch in. Bearing replacement is a simple job (once you remove transmission from the car) and about $75.00 in parts.
Transmission should be filled with Honda Manual Transmission Fluid or 10W40 motor oil. Do not use ATF or heavy gear oil.
dlg0187
Jun 25, 2011 06:38 PM
CoolGuy486
Sep 28, 2010 08:31 AM
