civic 2000 LX auto power drive side power window issue
Hi there,
I have an issue with my drive side power window issue. the window can not go fully up and the motor look strong. I got relatively new channel seal and followed the instructions from civic manual for alignment.
after I rolled up the window, you will see from the below pic, it does not fit right.
after I lower down like below
I can push the glass down, it will fit the channel to the right properly. you will see how much I can push down:
the only moving part I can see from the regulator is shown below:
do I really have to replace the whole assembly? which brand is matching the oem quality? hansun or ODV?
Re: civic 2000 LX auto power drive side power window issue
I already followed the civic instructions for the alignment. feel like the moving glass hold piece on the regulator is wobbling and that is why I can push down the glass that far. it does not have that issue on other ones.
