Crx ignition/fuel wiring issue
Old Oct 22, 2017 | 04:28 PM
hardrock2401's Avatar
Icon4 Crx ignition/fuel wiring issue
The car is a 88 si. Every once in a while, I will turn the key, the accessories will come on, but no main relay click, or fuel pump prime. During these intermittent problems, the car will start on starting fluid, so from what I have gathered, it is a fuel wiring problem. I replaced the ignition switch almost the day after getting the car, as it wouldn't stay in the run position, would start right up then die when you release the key.
The car has an older avital 2100 model alarm, that is tied into a couple of the wires off the ignition switch. The black/white wire from the switch is spiced into a relay of some sort, not quite sure what it does, but looks as if its tied into the alarm somehow. Then the black/yellow wire off the switch, has a t-tap off of it, again, not quite sure for what, but assuming it has to do with the alarm. When I originally changed the switch out, I installed it as is, without the relay spliced in, or without the t-tap on the black/yellow wire. The car would not start. I spliced the relay back in, and t-tapped the black/yellow wire, and the car started again. Then a few days later I started to have this intermittent problem I speak of. Could the ignition switch be bad, could this mess of an alarm setup be causing this. Just looking for ideas, as I am tired of my big *** laying upside down under the dash trying to follow and probe all the wires lol.
Old Oct 24, 2017 | 12:59 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Crx ignition/fuel wiring issue
No main relay click and no fuel pump priming.
I would be looking in that area.
Maybe the main relay needs to be fixed.
Maybe somebody installed a kill switch on one of the wires that feeds into the main relay.
Old Feb 6, 2018 | 07:20 PM
Thebb89's Avatar
had same issue on 91 rex pulled relay and opened it up cleaned with alcohol and q tip worked ever since also look for any burned areas on board
jc95148
Audio / Security / Video
Dec 16, 2012 02:57 PM
blasterman87
Nov 11, 2009 05:10 PM
hybridmoments
Jan 24, 2007 02:19 PM
tianporn
15
Feb 21, 2005 07:56 PM
daNattyFatty
Nov 3, 2001 04:49 PM
