Clutch or transmission slipping?
Old Oct 21, 2017 | 08:13 PM
Angel1815's Avatar
Icon5 Clutch or transmission slipping?
I have a 1997 integra and I just had an install for a new transmission and clutch. After the work was done I started driving the car and was fine the next day I was driving my car for like 10 minutes and I think the clutch started to slip. When I put the car in a gear it would accelerate until 3rpms and just rev and once at a complete stop in neutral it won’t even go in gear! Once it cools down it starts working well. I also had the master cylinder replaced. Also since it’s a stage 5 clutch the guy told me that I was burning the clutch thus doing that, but I’m pretty sure hot or not it’s not suppose to do that. Any ideas what it might be?
Old Oct 21, 2017 | 08:29 PM
egsleepercivic's Avatar
Default Re: Clutch or transmission slipping?
did you try adjusting the pedal ?
It might not be letting the clutch all the way out causing it to slip, heat up, and slip more
Old Oct 21, 2017 | 09:08 PM
Angel1815's Avatar
No I have not tried adjusting the pedal it has a high relase so how would I go about adjusting the pedal?
Old Oct 21, 2017 | 09:38 PM
look at the pedal, there is a locking nut on the push rod, then the shaft spins in or out ...giggity ...but really
Old Oct 22, 2017 | 06:56 AM
Angel1815's Avatar
Ok so if I loosen the the locking nut, Then the shaft pins will move? Also since this clutch has hight relase do I just move it a little?
Old Oct 22, 2017 | 04:24 PM
you more than likely will need to loosen the lock nut, then rotate the shaft in so its shorter, there should be a little play when the pedal is all the way out
Old Oct 22, 2017 | 04:30 PM
This from the helms for a 95 integra
FeelTheBass
21
Apr 7, 2022 11:41 PM
komat
Aug 6, 2010 12:04 PM
ac_attak
Jun 7, 2006 11:12 AM
range
Dec 1, 2003 02:01 AM
