95' Honda Civic DX B18 swapped drive axle replacement
I recently bought a '95 Civic DX with a B18B1 swap and unknown transmission (tag is missing). The car was said to have been swapped a couple of owners ago.
The passenger side outer CV joint is bad and we're having difficulty finding a drive axle the right length.
The drive axle we pulled out has 27T inboard, 26T outboard, and measures about 25 7/8" long overall (~657 mm).
According to information I found on g2ic.com, '90-00 Integra passenger drive axles are all the same - 27T inboard, 26T outboard (like I have), but 597 mm length. When I tried to install a drive axle for an Integra, it was too short, and then I measured my old one to compare.
What axle has the same splines as an Integra, but is about 2" longer?
Sorry guys I'm new to this where do I go to do a posting or maybe someone can help me I have a 95 Honda Civic B15 but I don't know if it's a B1 b7 b2 I've looked on the engine code and it does not have anything after the second b I'm going to turn this into my project and not quite sure what motor to go with that will built to my 5-speed
stevenstixx
May 13, 2014 09:48 AM
ocram
Oct 13, 2004 04:17 PM
