Tach help
Old Oct 16, 2017 | 01:53 PM
Karl Kluth's Avatar
Default Tach help
Have a 2000 Integra GS-R that's OBD2B. I switched to OBD1 with hondata, tach don't work. Witch ******* blue wire from distributor do I jump to what to make tach work? Have three blue wires coming from back of distributor!!! Baby blue, Blue with white stripe, and soild blue! Witch one do I jump, and then to where? Do I have to pull gauge cluster out? Thanks for the help!!!
Old Oct 18, 2017 | 03:13 PM
tony_2018's Avatar
Fish Twig
Default Re: Tach help
****** obd2b doesnt ****** have a ****** blue wire from ****** dizzy. ****** tach signal came from the ****** ecu
Old Oct 19, 2017 | 09:02 AM
MotorMouth93's Avatar
10 Year Member
There's a wire that has the RPM signal from the distributor in one of the blocked off plugs on the driver side of the engine bay by the shock tower. Those plugs are normally used for testing but, like tony_2018 said, you don't have a distributor RPM wire routed into the cabin with an OBD2B wire harness, but IIRC they still have the blue test wire over there.
kmak686
Jan 19, 2005 10:32 PM
Dropped90Integra
Jan 13, 2005 08:57 PM
beat_nut
Nov 16, 2004 02:45 PM
ozzyman
Sep 28, 2003 11:29 PM
92'gsrhatch
Jun 2, 2003 06:37 PM
