Honda CR-V & Element 2WD & 4WD Element & CR-V
roof rack thread size
Old Oct 16, 2017 | 05:59 AM
blounsb999's Avatar
Default roof rack thread size
2006 CRV. What size bolts do I need to attach a roof rack? Tried 1/4-20, 1/4-28 and M6-1.00
Old Oct 16, 2017 | 11:10 PM
mylament55's Avatar
Default Re: roof rack thread size
No bolts installed? Call dealer and ASK. I doubt Honda 'reinvented' the threaded fastener, so it's gonna be some standard size. 90% chance it's Metric.
When you install rack? Put some GREASE on the threads before socking the bolts down. Makes it much easier to remove and helps prevent rust.
Old Jul 22, 2018 | 10:34 AM
1122union's Avatar
Same problem. Tried all Metric and standard close to size at Ace Hardware and O'reily's with no success.
Old Jul 22, 2018 | 12:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Try metric bolts like M6-1.0 x 16. Also use a washer.
When Honda painted the CR-Vs they failed to protect the threads of the mounting bolts on the roof so they will likely have paint in them. Use a very small point screwdriver to scrap the paint away from the threads.
After you scrap the paint off, see if the rear license plate bolt threads in. The rear license plate bolt should be M6-1.0 x 20; slightly longer.
https://www.handa-accessories.com/crv/02CRVRACK.pdf
10HBmartian
Feb 3, 2012 06:55 AM
twentyhurtz
May 9, 2009 11:41 PM
SFC
12
Mar 31, 2007 12:52 PM
radeonboy
Apr 5, 2006 06:45 PM
E-Rok
Jan 26, 2004 07:59 AM
