Swap complete! JDM GSR with ITR S80 LSD - '93 Honda Civic del Sol Si
Old Oct 10, 2017 | 07:06 PM
Curlybandit's Avatar
Default Swap complete! JDM GSR with ITR S80 LSD - '93 Honda Civic del Sol Si
It's finally done!
Over the last 12 years of owning a Honda Civic of some form or another and building and tracking d-series motors, I've finally made the switch to a b-series. I had built an NA d16z6 that was making 158hp and 116trq to the wheels on a Mustang Dyno. I had built a custom 5-speed S40-B000 transmission with Quaife LSD and short-ratio gearing with a carbon synchro rebuild kit from Synchrotech. This past May 22nd I took my caar to the track like I usually do during the track season and disaster struck. An exhaust valve snapped at the neck and destroyed the head and block.
I decided that it was time for a new project. I wanted the same power, if not more, but with OEM Honda reliability and durability. A friend who deals in swaps had an OBD1 JDM GSR with low kilometres in excellent condition with an S80 LSD ITR transmission. I picked them up and now the swap is complete.
I've made the following modifications:
- Integra Type-R intake camshaft
- Skunk2 intake manifold
- 66mm Skunk2 throttle body
- Skunk2 intake filter with velocity stack
- Exedy clutch
- Competition Clutch 12.3lbs flywheel
- GReddy 4-2-1 single-piece header with 2.5" collector
- 2.5" exhaust
- Innovative transmission mount with 60A poly
- Innovative engine mounts with 75A poly
The intake piping coupler was too small for the larger throttle body so I attached the filter directly to the intake manifold. Once I get the correct coupler I'll be moving the filter to correct position.
I removed the AC and was planning on power steering but the pump I received was not the right one. So for now, no power steering.
It pulls very hard and the VTEC crossover is much more aggressive than my d16z6 was.
I've attached videos of three acceleration tests I made this evening and a pic of the engine bay.
Acceleration test #1:
Acceleration test #2:
Acceleration test #3
Curlybandit
Sep 7, 2018 04:02 AM
Curlybandit
May 23, 2018 08:58 PM
SikSol
Feb 16, 2006 08:59 PM
EGTURBO_again
Jul 24, 2005 04:12 AM
