TCM Ground
Old Oct 8, 2017 | 02:47 PM
Achs@1950's Avatar
Default TCM Ground
Does a TCM have to be bolted down to effect a ground condition, or is to ok to "just be there" with the cables plugged in under the floor bracket?
Old Oct 9, 2017 | 09:37 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: TCM Ground
I don't believe it being unbolted will affect how the TCM operates, but it is best to have it grounded to the chassis to prevent any possible damage from a voltage spike that could damaged an ungrounded control unit. If you must drive around with it unbolted/unsecure, use a jumper cable with alligator clips for an easy bonding of the case.
mish__
Suspension & Brakes
Nov 20, 2011 03:46 AM
SiMateoAko
Sep 10, 2005 07:09 PM
deviant1
Apr 19, 2004 10:16 PM
BlendedEJ8
Apr 25, 2003 06:40 AM
