Converting a Del Sol to power options
Old Oct 8, 2017 | 07:43 AM
DelSeoul's Avatar
Default Converting a Del Sol to power options
I currently have my eye on a 1993 Del Sol. The car in question has base options. I'm considering putting in all the power options that became available over the course of its production lifetime; power mirrors, door locks, A/C, cruise control, TransTop etc. What can I replace without too much trouble and what parts would I need? Thanks!
Old Oct 9, 2017 | 03:16 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Converting a Del Sol to power options
power option of.....SEARCH
Old Oct 9, 2017 | 05:20 PM
White_EG1's Avatar
Just don't, if you want power options get a Si or VTEC IMO
And the transtop adds 400 pounds to the car. With a b series and another passenger in the car a Transtop del sol easily weighs in at just under 3,000 pounds, that's horrible.
Old Oct 10, 2017 | 07:25 PM
Vector 25's Avatar
I dunno about a del so but in my 96 hatch I went to the junkyard and pulled two doors off of a ek coupe just make sure you cut enough of the harness so it's easy to extend. I even color coded my wires and put the wires in a loom it looked OE and I have power windows locks and mirrors which you need the mirror switch to use .I could of just pulled the regulator and motor but it's easier to just swap doors and wire them in but I think you need power del so doors which are harder to find in junkyards.
Old Oct 10, 2017 | 07:26 PM
Vector 25's Avatar
I dunno about a del so but in my 96 hatch I went to the junkyard and pulled two doors off of a ek coupe just make sure you cut enough of the harness so it's easy to extend. I even color coded my wires and put the wires in a loom it looked OE( sort of ) and I have power windows locks and mirrors which you need the mirror switch to use .I could of just pulled the regulator and motor but it's easier to just swap doors and wire them in but I think you need power del so doors which are harder to find in junkyards.
acidburn2k2
Dec 10, 2005 11:36 AM
delsolian
Nov 10, 2004 10:31 AM
dpine
Mar 27, 2004 08:30 AM
