Help me with this "power shifting"
Old Nov 11, 2002 | 02:09 PM
navybluelude's Avatar
Default Help me with this "power shifting"
Well i herd about power shifting and im just wondering how do you do it and what does it do.
Old Nov 11, 2002 | 02:15 PM
blacklude's Avatar
Default Re: Help me with this "power shifting" (navybluelude)
Basically what powershifting is changing gears without letting off the gas. So instead of letting off the gas and putting in the clutch to shift, you stay on the gas while pushing in the clutch and shifting.
Old Nov 11, 2002 | 03:12 PM
RAB's Avatar
RAB
Default Re: Help me with this "power shifting" (blacklude)
Say bye, bye to your clutch and pressure plate if you do it often.
Old Nov 11, 2002 | 04:11 PM
tonydatyga's Avatar
92 prelude type s ?
octane kit ?
Man I've been gone long
Old Nov 11, 2002 | 04:40 PM
laughinxxx's Avatar
New User
what does it do.
It ruins your transmission, clutch, and flywheel. Don't do it. Learn how to drive properly and quit listening to ricers.
Old Nov 11, 2002 | 08:09 PM
93 VTEC's Avatar
Default Re: Help me with this "power shifting" (laughinXXX)
It may be a little harder on your drivetrain, but it makes you that much quicker. If you cant shift quickly then DONT powershift, as you will just be bouncing off of the rev limiter between gears. My RPM's jump up about 200 then fall back down when I powershift. When you are going for max ET every little bit counts. I ran a 14.81 in my car with a slipping clutch when it was bone stock with 148,000 miles. I think that is driving.
Old Nov 13, 2002 | 06:08 PM
Sticky Tires's Avatar
* B A N N E D *
swiftly let off the gas a bit and shift into the gear without using the clutch while mashin back on the gas pedal. thats how i was taught, it gave a nice boot...with some pratice, you can do a nice launch. i did it before i traded in my VW Golf for my Lude. i can smell the clutch burnin.
[Modified by VtecDialect, 3:55 PM 11/22/2002]
Old Nov 13, 2002 | 09:07 PM
Honda318dx's Avatar
Default Re: Help me with this "power shifting" (VtecDialect)
Just don't do it, prelude trannies are weak enough....
Old Nov 13, 2002 | 09:25 PM
rjr162's Avatar
before you hit redline, swiftly let off the gas a bit and shift into the gear without using the clutch while mashin back on the gas pedal. thats how i was taught, it gave a nice boot...with some pratice, you can do a nice launch. i did it before i traded in my VW Golf for my Lude. i can smell the clutch burnin. do it wrong and <U>slowly</U> fukc ya whole **** up
He got it right. Not letting of the gas and using the clutch is called "speed shifting". When you don't use the clutch at all, that's power shifting. Power shifting really screws stuff up, because you're just jamming gears together weither they are lined up or not. Easy way to rip a tooth off of a gear or worse. Speed shifting will put a bit more stress than normal shifting, obviously, but isn't nearly as bad as power shifting. speed shifting does the same as revving the engine some and dumping the clutch, only you're already moving.
[Modified by VtecDialect, 10:17 PM 11/13/2002]
Old Nov 13, 2002 | 09:53 PM
EH2DX's Avatar
powershifting to the side, i wanna know where you got a 92 prelude type-S...
beandip
Honda S2000
35
Apr 15, 2006 03:06 PM
peja43916
Sep 23, 2005 03:57 AM
i20ar
Sep 8, 2004 10:09 AM
Integra21
May 26, 2003 09:55 AM
95vtecgook
Feb 22, 2003 09:25 PM
