Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda civic 2001 AC leaking liquid by the drain hose
Old Oct 4, 2017 | 04:45 PM
civic@2001's Avatar
Default Honda civic 2001 AC leaking liquid by the drain hose
I have a civic LX 2001that is leaking a lot a water by the the drain hose of the Air Conditioner located next to the engine and transmission with the engine cold (or hot) in 5-10 min after is turned on. What could be the cause and solution?. I'm worry of leaking antifreeze from the coolant Is this possibly? first is little oil leak then is the water from the drain hose from engine to the bottom rear of the car.
Old Oct 4, 2017 | 08:14 PM
toyomatt84's Avatar
Sanji
Default Re: Honda civic 2001 AC leaking liquid by the drain hose
Its normal for an A/C system to drain water there under the passenger footwell, as the built up moisture from cooling the interior collects there.
Old Oct 4, 2017 | 10:40 PM
civic@2001's Avatar
thanks for the response how much is normal? the ac is working ok by the way... is there an AC condenser like the other cars?
metalmole
Jun 18, 2014 10:30 PM
PF14
Sep 2, 2013 09:57 AM
DACteg
Jul 27, 2010 11:04 AM
adrenalinesaint
Aug 30, 2007 11:23 AM
Josh Carr
May 12, 2004 08:10 AM
