97 Integra GSR engine wiring question
Old Oct 4, 2017 | 07:28 AM
Attila's Avatar
Default 97 Integra GSR engine wiring question
I just purchased a 97 GSR 5-speed that runs great, but I have noticed a few issues. The biggest one is that the reverse lights do not work. I did some research and digging and found that the sensor in the transmission had no wires running to it. I also noticed a few other areas that we will say aren't factory. Lol. So my question is can I get an engine wiring harness from any 96-01 GSR or were there changes between the model years that will limit what I can use? Thanks for any help.
Old Oct 7, 2017 | 04:57 PM
jdmark1's Avatar
Default Re: 97 Integra GSR engine wiring question
I'm not too familiar with the slight differences between GSR harnesses over the years but as far as the B18B harness goes for manuals, it's: 94-95 is the same, 96-97 is the same, 98-99 is the same, and 00-01 is the same. But what I would look for is a GSR harness that has the same OBD gen as your car's ecu and you should be golden. your's is a 97, so 96 thru 99 are all OBD2A. So any gsr harness from those years should work fine. I think 98-99 will have a plug for the charcoal canister that you wouldn't need to use but don't quote me on it. As far as your back-up light goes, that would be part of the transmission harness and can be bought fairly inexpensively here.
akoreanyoungsta
Texas -OK -LA (Sales)
Jul 14, 2006 06:07 PM
epak
Jul 14, 2006 05:55 PM
akoreanyoungsta
Jul 14, 2006 05:51 PM
Ri5e
Apr 4, 2003 01:38 PM
1bad-eg
Jan 17, 2003 11:32 AM
