B20 idle issue in ek swap
Hey guys so I swapped a good running b20b4 into my 99 ek checked compression 139 on all 4 cylinders new plugs cap rotor no vacuum leaks checked three times smoke tested and brake clean tested no cel revs out fine and perfect no cut out replaced ect sensor map sensor tps and it's calibrated to spec new intake gakset new injectors flow tested and checked timing three times!!! Dead on the money I've been working on this for three months please help lol Idk what else to do oh yeah the problem is at idle after warmed up idles at 750 and all the sudden just does out of know where but starts right back up Everytime and I also replaced iacv and fuel filter when it dies it acts like I turned the motor off it makes no sense!!! I've checked the harnessgrounds and cleaned them especially the thermostat housing ground still no luck I also replaced fuel pump with the crv fuel pump that the engine came out of and also adjusted valves to spec any ideas would be help thanks guys!!
doodooheadfart
22
Oct 29, 2007 12:01 PM
