LS crank in a GSR
Old Sep 25, 2017 | 11:56 AM
gorillaglue#4's Avatar
Default LS crank in a GSR
Im pretty sure I am posting this in the right place, if Im not mods please move this. I was about to send off my spare ls block to CNCwerx and I couldn't get the crank out with my Walmart impact driver so I said to myself lets see if I can just buy a sleeved LS block. I was looking and seen a CSS's GSR block for 350, I hoped on that ****. When I went to meet the kid to buy it from he was younger than me and had a kid a week before hand right before hurricane Irma.
TLDR
Im putting my LS crank in the GSR block because I already have forged pistons and rods and a decent crank is 300 on ebay. What crank pulley do I want to use? I am going to get it balanced.
Old Sep 25, 2017 | 12:14 PM
TheShodan's Avatar
Moderator
Default Re: LS crank in a GSR
This had been done quite a bit, and well-documented. The LS rods must go with the crank, everything else can be GS-R. Please remove oil squirters. Compression will be determined by piston bore & compression
Old Sep 25, 2017 | 12:53 PM
From the increase in stroke is there anymore stress on the bearings than normal?
Old Sep 25, 2017 | 02:08 PM
TheShodan's Avatar
Moderator
No. There is no correlation between bearing stress and stroke. It is no different than any other "striker build". Google search G"LS"R.
carlossolorzano
May 27, 2012 01:12 AM
Gaspari
Sep 14, 2010 01:42 PM
haas480
Sep 1, 2009 04:09 AM
patrick4588
Oct 18, 2007 12:33 PM
Mostecstreethb
Feb 19, 2007 02:19 AM
