new build startup issue
Old Sep 23, 2017 | 07:43 PM
jester1614's Avatar
Default new build startup issue
I am currently working on getting my project 88 civic up and running. I have spent a good part of the day fighting to get it started, when i set the mechanical timing correct with the timing marks on the cam gear with the horizontal marks flush with the top of the cylinder head and one pointing towards 7o -clock the car doesn't want to run (no backfires) but tries very hard to start with the distributor fully retarded. with it like that it seems like it is only a few degrees of timing away from running.
I have tried retarding and advancing the mechanical timing both 1 and 2 teeth in each direction to no avail.
car cranks fine, and has spark to all 4 cylinders, I need to check the injectors but adding starter fluid does not help so I am assuming as of now that it is not a fueling issue, fuel is verified as far as leaving the filter headed to the rail.
as it sits right now is as such
d16z6 stock head and block
stock crank
stock cam
stock cam gear
stock injectors
eagle connecting rods
vitara pistons
walboro 255 fuel pump
unmodified pr4 and p28 ecus have been used to try and start the vehicle
pr4 shows iat sensor code, p28 uses a jumper harness
.This image has been resized. Click this bar to view the full image.Report this imageThis image has been resized. Click this bar to view the full image.Report this image
I have jumped the drivers side plug to bypass ecu timing adjustments
I have visually verified that when the crank shows tdc in regards to mechanical timing adjustments, cyl 1 is at tdc and the rotor in the distributor is pointing at cylinder 1. I have also checked the spark plug wire order many many times
Thanks in advance for all your help and suggestions
Old Sep 25, 2017 | 05:15 AM
browngrasscat's Avatar
Default Re: new build startup issue
Compression?
The vitara pistons and eagle rods - as I understand it, the wrong setup will tank compression (7:1 or something like that) which would make it easy to crank, but hard to start (it's easier to blow stuff up under pressure and hot, compression does both).
Just throwing ideas around.
Old Sep 25, 2017 | 09:56 AM
24TEN's Avatar
PHANTOM MENACE
Agreed on compression being too low. Are you planning on running a turbo along with it?
EG-SIXV-TEC
Jun 14, 2013 08:22 PM
ImmaculateDelSol
Aug 11, 2009 01:29 PM
1point7db2
Aug 13, 2006 05:59 AM
Neutex22
Jan 15, 2005 09:39 AM
JaiDM
14
Jan 6, 2003 04:58 PM
